I have a Nexus 6p. When I cast from any compatible app -- I'll use Google Play as an example -- everything starts off peachy. A few minutes later, I'll get my phone out of my pocket, open up Play Music and will be unable to reconnect to control the cast. I'll go to the cast app and it's about 50/50 if I'll be able to change volume or stop casting from there -- sometimes it shows the cast device in question as not in use, but it also won't show the control menu for that device so I'm just stuck. (Sometimes, it shows an audio device as a video device.)
Anyway, in the end I can unplug the cast device to reset it if nothing else works, but it's really a pain. I wonder if there is a setting which improves staying connected, even if it means a greater battery drain.
