1. mvasquez009's Avatar
    ok so ive had nothing but problems with my chromcast since ive bought it..it doesnt show up as connected chromecasts in the chromecast google play app and videos through netflix and google play constantly stop to load play in low quality or stop playing all together..but what im wondering is that when i casted netflix to my chromeccast through my computer today for the first time it played basically perfectly in hd the whole time but when i cast from my netlfix on my phone its low quality and constanlty buffers..i have a gs4....any suggestions this is driving me crazy!
    08-13-2013 09:26 PM
  2. Devlyn16's Avatar
    OK on the surface this looks like it is a wi-fi/router issue. But to clairify you wil need to check a few things. IS the PC casting conected tot eh riouter by Wi-Fi or a wired [Cat5] connection?
    what type of router do you have. Is UnPnP enabled? Do you have any sort of isolation enabled on the router?
    Netflix usually adjusts the quality of the video based on connection signal strength.
    08-14-2013 11:52 AM
  1. KIES FIRMWARE UPDATE PROBLEM [Samsung Galaxy Ace 2]
    By AcousticBison in forum General Help and How To
    Last Post: 12-14-2013, 02:53 AM
  2. Replies: 5
    Last Post: 09-04-2013, 03:26 PM
  3. sd card erased ! please help
    By abdullah98 in forum Samsung Galaxy S3
    Last Post: 08-16-2013, 07:19 AM
  4. Casting from PC Chroe tab...
    By glrobin in forum Google Chromecast
    Last Post: 08-13-2013, 11:19 PM
  5. help on unlocking the at&t version that does not support voice
    By donwhize in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 08-13-2013, 11:09 PM
