1. pgtrr's Avatar
    For say a 250ga buried LPG tank with a standard or R3D dial - is there some sort of wifi device I can connect to the dial and be able to read/monitor propane tank levels remotely without having to physically go out and inspect the tank? Maybe even have an alarm trigger if the propane gets too low?
    Likewise for say a several thousand gallon water storage tank I would like to be able to monitor water levels remotely - possibly via Google Home. I think they make simple alarms that are triggered when a float on a wire or alarm drops to a certain level. If there's not already a water tank sensor for Google Home - maybe there's a hobbyist device out there I could hook up a normally-open or normally-closed switch device to that works w/ Google Home and I could wire up to a water float switch?
    I think there's some stand-alone solutions - but now I'm curious if there are any that might be adapted to working with Google Home.
    Thanks,
    09-27-2020 02:26 AM
  2. Rukbat's Avatar
    Something like this will monitor LPG tanks. These may also be of interest to you.
    09-27-2020 12:54 PM
  3. pgtrr's Avatar
    ...and there it is - thanks!
    10-03-2020 03:24 PM
  1. Thoughts on the Note 20 and the Samsung Access program
    By Hornswoggled in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-28-2020, 05:02 PM
  2. Unable to restore my whatsapp backup from google drive
    Last Post: 09-28-2020, 11:30 AM
  3. Strange behaviour google home app
    By Goodlegoo in forum Google Home Hub
    Last Post: 09-27-2020, 01:10 PM
  4. Network storage service
    Last Post: 09-26-2020, 03:45 PM
  5. Skin and Case on N20 Ultra.
    By bandofbrothers2112 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-26-2020, 02:23 PM
