1. farmwersteve's Avatar
    I just got the new large screen Google nest hub max.
    It is replacing the 7" Google nest hub, in fact in the exact same location with the same WiFi network and everything else status quo
    My point is that this new nest hub max keeps dropping the Wi-Fi internet connection.
    It's very frustrating to watch it go to the connection screen every 5 minutes.
    I have unplugged and restarted internet connection several times. Anyone else with this issue?
    10-05-2019 08:20 PM
  2. me just saying's Avatar
    did you do a power cycle on your router? If not, give that a try.
    B. Diddy likes this.
    10-05-2019 08:57 PM
  3. B. Diddy's Avatar
    ... or is that what you mean by unplugging and restarting the internet connection?
    I don't have a Google smart display, but is there an easy way to make sure it's fully up to date, both software and firmware-wise?
    10-05-2019 09:29 PM
  4. farmwersteve's Avatar
    Yep. I did that
    10-05-2019 10:19 PM
  5. farmwersteve's Avatar
    It automatically updates itself when starting the setup process. So the software should only be about 4 days old if it doesn't auto check for updates.
    I am going to put it directly beside the WiFi router to see if that helps
    Also, I guess there might be a router setting on my network that is kicking it off randomly.
    I should call Google, but too tired tonight to go through that process.
    Already spent enough time with them last week to get my wifes pixel 3xl rma for terrible outgoing phone call quality
    10-05-2019 10:22 PM
  6. me just saying's Avatar
    there is such thing as being too close. try to keep it at least free feet away. also try swapping 2.4GHz and 5GHz bands. finally if your router has smart connect, try turning it off.
    10-05-2019 10:37 PM
  7. farmwersteve's Avatar
    I fixed my issue. a new wireless router did the trick
    B. Diddy, pontiac005 and Rukbat like this.
    10-20-2019 10:21 AM
  1. Why is my note 10 plus battery dropping from 5 or 4 percent straight to zero
    Last Post: 10-06-2019, 01:08 PM
  2. Samsung Experience Home keeps stopping
    Last Post: 10-05-2019, 05:52 PM
  3. Can I format an SD card to be the default storage on my new phone?
    Last Post: 10-05-2019, 05:03 PM
  4. PC Remote Connection on startup?
    By crazyralph90 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-05-2019, 03:14 PM
  5. Question about Internet speed
    By JoeSandfort in forum Ask a Question
    Last Post: 10-05-2019, 11:57 AM
