dgr_1983
Yeah thanks, I discovered that the usb part that connects to the tablet is damaged & have been using my htc cable to charge it instead. Will have to invest in another cable & the pogo charger.
When does the timer start running? for the battery? I charged the whole night last night then unplugged it around 7Am this morning.Now its 5PM in the afternoon and the battery usage says its been running for 11 hours
so when does the timer start running? is it when you unplug the charger or when the battery becomes full does the timer for the battery usage starts ticking?
please clarify thanks guys
It is supposed to be when it is unplugged. Not sure how/why you got 11 hours instead of 10.
It's supposed to start a few seconds after you plug the charger in.
