nexus 10 battery
dgr_1983
3
Yeah thanks, I discovered that the usb part that connects to the tablet is damaged & have been using my htc cable to charge it instead. Will have to invest in another cable & the pogo charger.
Atiya
138
When does the timer start running? for the battery? I charged the whole night last night then unplugged it around 7Am this morning.Now its 5PM in the afternoon and the battery usage says its been running for 11 hours
so when does the timer start running? is it when you unplug the charger or when the battery becomes full does the timer for the battery usage starts ticking?
please clarify thanks guys
crxssi
Linux: The power beneath
May 31, 2010
2,668
155
It is supposed to be when it is unplugged. Not sure how/why you got 11 hours instead of 10.
paintdrinkingpete
2,917
276
It's supposed to start a few seconds after you plug the charger in.
I've never been able to figure this one out... I had always assumed it started when you unplugged from charger, as it says "xx time on battery", however there have definitely been times when I've plugged my phone/tablet in for a short amount of time for a partial charge when the timer didn't reset, so I wondered if it had to be a full charge, but apparently that's not the case either...
What I've found is that as long as I've had it plugged in for a substantial amount of time, it will reset the timer a few seconds after I unplug it. I'm not sure how much time is "substantial", but I know that, for example, a 20-minute charge doesn't always reset the timer for me.
dave1216
16
You can always manually reset the battery log time with the button in the upper right corner on the battery display (recycle).
BTW, I am having some weird battery issues myself. Twice now the battery has drained for short periods for no apparent reason. It is doing it in sleep mode. Besides some battery issue itself, my guess was that it is trying to connect to WiFI while sleeping and having trouble, some app is still running, or my case I just got is doing something funny with the open/close. Still troubleshoot (not using the case first).
Atiya
138
why does my battery log
look like this?
I clicked the reset app something ..whats wrong
MarcosVo
