1. Super Suit 12's Avatar
    Recently, I attempted to turn on my tablet with wet fingers in a humid room. It turned on as expected... then powered down. And then started to boot. And shut down. This continued to happen until it ran out of battery. (I did not sleep well) Now when I try to charge it, it repeatedly shows the charging icon like it does when you hit the power button, so the problem persists.
    My guess is that the power button contacts or whatever they're called have gotten wet and need to dry but it's been 48+ hours. Am I just impatient or is there something more wrong with it? I took the back panel off but I haven't found a small enough screwdriver to remove the whole case.
    08-28-2017 07:21 AM
  2. N4Newbie's Avatar
    Just how wet were your fingers?
    I would be very surprised if the power button on the Nexus 10 has exposed contacts as that is not normally the way it is done on modern devices. The "button" that you push typically acts on another button, part of a semi-sealed switch assembly.
    I suppose if your finger was *really* wet...
    Google Nexus 10 Take Apart First Look
    08-28-2017 09:23 AM
  3. Super Suit 12's Avatar
    True. I didn't think of that.
    No clue what the issue is then... guess I'll be taking it apart.
    08-28-2017 11:20 AM
  1. Why is my nexus 5x draining battery so quickly?
    Last Post: 08-30-2017, 09:25 AM
  2. replacement with no batt or sim card
    Last Post: 08-28-2017, 06:25 AM
  3. Samsung S7 G930 Nougat version. Gallery - contacts photos issue
    By tmobyrne in forum Legacy Android & Other OS's
    Last Post: 08-28-2017, 05:40 AM
  4. Settings button doesn't have display
    Last Post: 08-28-2017, 12:50 AM
  5. S-Power Planning
    Last Post: 08-27-2017, 11:06 PM
