    I have a nexus 10 that is about five years old. The battery is rubbish and I have finally got around to buying a replacement. However before I do the change over I want to check to see if all the data will be lost as the system will factory reset after I disconnect the battery???
    If this is going to happen is there a good app for backing up to a pc??
    Cheers for any help😀
    03-26-2018 04:58 PM
  2. belodion's Avatar
    Phones with removable batteries don't do that when the battery is removed so I think you'll be okay.
    03-26-2018 05:32 PM
  3. Vauga's Avatar
    Hi thanks for the reply. Do you anybody that has completed a battery change and not lost the data? Also maybe there is a back up app to copy/clone the tablet before I remove the battery?
    Sorry to be a pain a appreciate any responses.
    03-28-2018 06:00 AM
  4. belodion's Avatar
    Well, there's certainly no harm in doing a full backup beforehand, although I don't think it would be necessary. Prudent, yes, but not necessary. That could be done via Settings, Backup & Reset.
    I'll move the thread to the Nexus 10 forum for comments from other users.
    Welcome as a new member.
    03-28-2018 06:24 AM
  5. Rukbat's Avatar
    I've replaced batteries in many Android devices over the years - pulled them just to restart a stuck device, etc. Never lost a byte of data. The only thing you can lose is data you're working on that you don't save before replacing the battery, the same as if you turn the phone off before saving. Once something is saved, it's in "non-volatile" storage, meaning that it doesn't leave unless you delete it or flash a new ROM or something else that's supposed to delete data. (Of course if you damage the tablet [and doing your own battery replacement on a tablet always leaves that possibility], all your data can be gone [depending on what you damage].)
    So, as belodion said, it can't hurt. (You should always have everything backed up anyway - what it you dropped the tablet and someone stepped on it hard enough to damage the motherboard? The data would go with it.) But see Backing up an Android Device to back up everything. (There's no reason to not have at least one backup - there are so many free cloud accounts. I currently maintain 3 - 2 cloud accounts and one backup on a PC.)
    03-28-2018 04:49 PM
  1. my samsung galaxy s 8 seems to have a gallery virus. it won't delete pics
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-27-2018, 11:15 AM
  2. Why is my lg aristo phone typing on its own?
    Last Post: 03-27-2018, 02:41 AM
  3. New to Android, check iconx battery?
    Last Post: 03-26-2018, 05:30 PM
  4. Looking for the most battery-friendly device-tracking (GPS) app
    Last Post: 03-26-2018, 04:46 PM
  5. I dont like candy gallery, how do i get outta it
    Last Post: 03-26-2018, 04:01 PM
