    I replaced the battery in a Nexus 10. I turned it on with the battery Indicator at 100%, and it did not move at all, until after some time of using it, the screen flickered then it died.
    When I charged it, the indicator still shows 100%.
    Do I need to take i apart again, or can this be fixed some other way?
    08-12-2018 05:57 AM
  2. Rukbat's Avatar
    Run it through a few cycles. If it still does it, you probably have a bad battery.
    08-12-2018 01:31 PM
  3. Glurmo's Avatar
    Hello,
    I have put a different battery in the Nexus 10, the battery indicator now works except the screen has now got a
    1 centimetre wide dead zone, top to bottom (landscape) on right side of the screen which is unresponsive.
    Could this be due to a ribbon cable being replaced incorrectly or have i permanently damaged something.
    Many Thanks
    08-18-2018 05:06 AM
  4. annhvass's Avatar
    Hi,
    I am hoping someone can help me - from a few searches I cannot seem to find this problem already reported. I decided to replace my goodle nexus 10 battery - first time I ahve done something like this but following all instructions and videos it was going well. However, using this battery which I have checked and double checked is the right one CS-SGP811SL Battery 8000mAh compatible with [SAMSUNG] GT-P8110, GTP8110-HA32ARB, [GOOGLE] Nexus 10 replaces SP3496A8H, SP3496A8H(1S2P) from here https://amzn.eu/d/hjDymgC
    Once I get to the point I want to add the new battery the battery connection is longer in the new battery than in the old battery which means that I cannot connect the battery. Does that make sense - anyone come across this before? Please see two photos attached one where I have connected the battery and you can see the screws are out by 1mm - the other where it is lined up to fit the screws but the connector is then out by 1mm.
    Am I missing something really obvious - anyone have any guidance? Is this just the wrong battery?
    08-23-2022 07:45 AM
  5. mustang7757's Avatar
    Hi,
    Welcome to AC!
    Might want take to local repair shop and ask for assistance maybe they can give some tips and maybe tip them or buy them coffee if they do help without charging
    08-26-2022 09:51 PM
  1. Replies: 15
    Last Post: 08-14-2018, 10:44 PM
  2. Galaxy S6 Active... is an LCD replacement what I need?
    Last Post: 08-12-2018, 12:32 PM
  3. Being charged for phone while waiting for replacement!
    Last Post: 08-11-2018, 08:36 PM
  4. Google Search Widget Issue
    By GMoney653 in forum Ask a Question
    Last Post: 08-11-2018, 02:08 PM
  5. Anybody having issues with Fitbit sync after Pie?
    By gerrya in forum Google Pixel & Pixel XL
    Last Post: 08-11-2018, 12:16 PM
