hunterhp
Phil is it possible you could post speed tests on tmobile 42Mbps HSPA+ network?
Sent from my GT-N7000 using Tapatalk 2
It's not coming with LTE. Period. Maybe later, but not now. And I care about now.
Is it worth $350 unlocked, off contract? You'd better believe it.
How do I find out what podcasts I can get?
Generally just do a search for whatever your looking for
On google play it says that the Nexus 4 has slimport HDMI under their connectivity section, however I have not seen any reviewers speak about this. Is their in fact slimport HDMI out or is this a typo on the Nexus page? Thanks!
https://forums.androidcentral.com/e...nes?playredirect=true&hl=en-US&token=Bkpr8GWE
Does anyone know how the new "airplay" feature on the Nexus 4 work? (connect the Nexus 4 to the TV wirelessly I believe)
I owned a Mytouch 4G (this thing is like 2 years old already) which has a feature called "Screenshare" that let you wirelessly play videos and pics to your TV through DLNA, but I couldn't get it to work, right now I only know how to use HDMI cable to connect my phone to TV, so that's why when i heard about the new feature on the Nexus 4, I really wanna know how to make it work.... THANKS FOR READING THIS
Thanks! I wonder if this is implemented through software as its using the Micro USB port, or if it is different hardware. I would assume the latter but if it is software I wonder if the N7 will see this and the N10.Nope. you heard it right. it has a slimport
Nexus 4 boasts SlimPort support for tethered display sharing -- Engadget
Analogix unveils SlimPort Nexus 4 accessories - SlashGear
Battery life is a lil better than the Iphone 5 by about 15%.. I dont have one but side by side use on a recent trip the 4 lasted longer but I was on ATT hspa while she was on att lte..
Earbuds are something that normally users have and to keep the cost down they werent included... also LG makes really crappy throw in headphones and you wouldnt want those..
I use an app called BEYONDPOD.. its in the market and I enjoy it. Its part RSS reader as well as Podcast player.. its a couple of bucks but there are free ones as well..
Panda
Thanks for the info. I assume the iPhone 5 will get longer screen on time, though?
so phil what about the back of This phone...is it too fragile?
Define "too fragile."
