Google Support says charging a Nexus 4 for longer than 2 hrs will kill the battery
JoeSh
Like many of us my Nexus 4's battery life is poor. I've read many threads about this but I figured I'd see what Google Support's "official" answer was. Here's what they wrote:
Thank you for contacting Google Play Support Team. You called in today with questions about your Nexus 4 battery life. It was a pleasure speaking with you today, I can understand how this may cause you some frustration. You emailed me saying that your device still hasn't fully charged. As i explained before the device normally does charge in about two hours. Yet if you have left your device on the charger for over two hours on a number of occasions you could experience problems with your battery. If the problem still occurs you can call in and get your device replaced. If you have any further questions or concerns please feel free to reply back to this email directly.
There can't be any truth to this, right? Modern phones have really smart charging systems to manage their super-dense super-finicky batteries so overcharging shouldn't be possible, correct? I mean if it were, I suspect the phone might burst or catch fire.
SpiralBorg
367
Perhaps, it happened with some units, and it might be a more serious issue. Battery's overcharging shouldn't kill the battery in its entirety, but might be the battery the Nexus 4 uses. Maybe its a design flaw.
Sent from my MZ604 using Android Central Forums
TvTechGuru
558
20
They are full of crap! I ran my battery down to 6% and then put it on the wireless charger and it took just over 4 hours to fully charge it. Heck the other night I had it down to 21% and put it on the wireless charger and then went to sleep. It probably only took 3 hours to charge it from that point.
Now I wouldn't recommend leaving it plugged in to any charger every time for several hours after its full. I don't know what could happen. But, pretty much all new phones and chargers have a built in feature that turns off the powering function of the charger so that the phone doesn't get overcharged.
peejay1977
207
Any modern device with a Li-Po battery should be fine being left on charge an indefinite period of time. Sounds like Google are covering their backsides rather than giving out correct information.
boparunsxc
133
Once the battery is charged, the current just cycles through the phone and back out to the charger.
mhinc
2,051
Doesn't matter how long you leave it plugged in but I bet they are trained to say that to avoid being blamed for anything
Anbaric
3
I wonder if the reply is just badly phrased. Maybe they just mean it should charge in 2 hours and, if it has taken longer 'on a number of occasions' you have a problem.
atari_guy
8
Isn't it common practice to plug your phone in at night and unplug it in the morning? I've been doing that with all my phones for years.
KwietStorm
184
If that's your common practice, then that's your common practice.
Rizy7
638
Im pretty sure what the person was trying to say is that if the battery doesnt fully charge within a couple of hours on a number of occasions then you might have a problem with your battery.
sonicresidue
261
Everything that I've read here, including my own experience, suggests it takes 3 - 3 1/2 hours for the battery to fully charge 18% or less capacity. If it's supposed to charge fully in two hours than there are an awful lot of faulty batteries.
zedorda
2,594
178
The less time a li-po battery spends at 100% or below 5% the longer it will last. Lithium-ion batteries wear most at either extreme. So charge often in 2 hour or less time frames and try and keep your device at 20%-80% as much as possible and you will see great longevity.
paintdrinkingpete
2,917
276
BlackBerry, HTC Thunderbolt, Samsung Galaxy S 3 -- I've left them all on a charger overnight when I sleep on *most* nights. Never noticed any ill effects because of it.
I am in no way an expert on this subject, but I've heard on several occasions that allowing your phone run all the way down to zero isn't good for it, but that today's modern batteries don't have issues with "memory" or being left to charge too long. In my experience, that has been true.
I guess if the device/kernel was still trying to drive current to the battery once it's fully charged, that could be bad for it...very bad for it (Is this even possible? -- Again, not very knowledgeable on this subject)...as others have mentioned though, once it hits 100%, it should stop charging, allow the battery to discharge slightly, charge again, repeat until unplugged.
PaulMilander
103
I can be plug mine in at bedtime and take it off in the morning, been doing this for 10 plus years as all my friends do. I'm not setting my alarm for fours later to unplug my phone
oberkc
136
That is also my understanding with LiPo batteries (and perhaps other types). As a point of comparison, my little Prius C automatically manages the battery and appears to work very hard at keeping it in that mid state of charge. I expect these batteries to last a LONG time.
zedorda
2,594
178
akbarramadhani12
