Hi all
So, I received my brand new Nexus 4, 8gig version.
Out of the box it was running Android 4.2 - build JOP40C.
This is my first smart phone, so I went to google play and started loading up on apps that I wanted.
I noticed though that my phone would connect via the photo mode ok - appearing as a device in my computer and letting me see the pictures folder. But when I set it to be an MTP device I couldn't see anything. (Im running Win 7)
I figured this was a driver issue - the next thing I did was to get the nexus root toolkit and unlock and root my device.
I presumed this worked, but my phone remained invisible if connected as an MTP device.
I then tried to use the nexus root toolkit to update to 4.2.2 (I downloaded the files from google's dev page called occam or something) and tried to apply these (making sure to follow every step) however the command prompt pops up and it gives a list of things it's doing and times to complete, eventually it says not found for a few items and finishes by saying 'failed'.
So my phone is still 4.2. I used superSU to unroot, and deleted the box free software (can't recall the exact name) and tried again to update, again to no avail.
I've got no mobile web left, so I'll try to find a wifi today to do an OTA update. Does anybody have any ideas as to how/why my phone is not visible in my computer when connected as an MTP device, and further more why nexus root toolkit cannot update the android version?
Help will be much appreciated!
Regards
Edit - should I just try this? http://forums.androidcentral.com/ne...3923-guide-nexus-4-factory-image-restore.html
Regards
