1. naveen sangisetty's Avatar
    I brought Skull candy headset and it worked perfectly well for a month. Then all of a sudden, I am having problems answering calls, the answer/cut button on the headset is not working and the music is pausing randomly and I had to unlock my phone and play the music again.
    08-08-2013 02:01 AM
  2. B. Diddy's Avatar
    Are you sure it's the headset that's acting up? Maybe there's a problem with the phone or the phone jack. Try the headset on someone else's phone and see if it works. If it doesn't, then clearly the headset's not working right, and you should see if you can return or exchange it. If the headset works on someone else's phone, then maybe there's some debris in your headphone jack. Take a damp toothpick and root around in the jack to see if you can pull out any lint or other debris. You could also try using a can of compressed air to blow out any debris.
    08-08-2013 02:52 AM
  1. What to put on my Nexus One?
    By toddjy in forum Google / HTC Nexus One
    Last Post: 08-11-2013, 07:09 AM
  2. New nexus 7 1080p streaming question
    By m.vasquez009 in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-10-2013, 10:26 PM
  3. Nexus 4 adding media
    By Berserkers in forum Google Nexus 4
    Last Post: 08-09-2013, 10:32 PM
  4. Replies: 7
    Last Post: 08-08-2013, 12:15 PM
  5. Galaxy S4 Mini Problems
    By wynster in forum Samsung Galaxy S4 Mini
    Last Post: 08-08-2013, 02:56 AM
