1. Octaviannn's Avatar
    Can anyone say me what to do if maps are draining my battery? Its using 40% of the battery. I usually "force stop" the app. Any other ideas?
    P.s. gps is off, but google locations is ALWAYS on. Maps are draining my battery only after using navigationsystem.
    Posted from my Nexus 4
    08-14-2013 02:38 PM
  2. B. Diddy's Avatar
    I wonder if Nav is staying awake and using battery even after you're done using it. I never use Nav, so I can't be sure.
    One thing you could try is to turn off Location Reporting, which lets other people know where you are (used for the old Latitudes app, now incorporated into Google+). Location Reporting tends to increase the number of wake locks executed by the phone (in order to access the web and report your location), which can use up battery. Turning off Location Reporting won't affect the ability of apps to access your location. Go to Maps/Settings/Google location settings, tap Location Reporting, and turn it off, then see what happens.
    You can also install an app like Wake Lock Detector to see what specifically is using up most battery power.
    08-14-2013 03:32 PM
  3. Octaviannn's Avatar
    Well, i would like to keep location reporting on. It does suck some juice, but not so much, and not maps.
    08-14-2013 03:39 PM
  4. Octaviannn's Avatar
    I turned gos off, then i restarted. Inly after this it went really off. I dint want to restart my phone always. :/ is there another way to fix it? Hmm i think this is a 4.3 bug.
    08-16-2013 09:55 AM
  5. still1's Avatar
    I hope you are using the latest maps!!! Maps 7.0 saves a lot of battery.
    if nothing help, clear data/cache for maps and set it up again
    08-16-2013 10:20 AM
  6. Octaviannn's Avatar
    Its version 7.0.2
    And the bug is that gps is not turning off, only agter a restart.
    08-16-2013 12:40 PM
  1. Using automation apps to save battery (and which one works best)
    By LeoRex in forum General News & Discussion
    Last Post: 06-04-2015, 11:21 PM
  2. Insane overnight battery drain
    By natedog155 in forum Samsung Galaxy S4
    Last Post: 09-16-2013, 12:35 AM
  3. Replies: 8
    Last Post: 08-21-2013, 08:01 AM
  4. How do i add videos to my S4 active ?
    By xxaym in forum General Help and How To
    Last Post: 08-15-2013, 01:33 PM
  5. Please help - What is this button on my phone?
    By Adolf Satzinger in forum General Help and How To
    Last Post: 08-14-2013, 01:47 PM
