Re: Solved - Nexus 4 Won't Turn On or Charge
Do you have Android 4.3 installed? I am wondering if the 4.3 update helped to contribute to these problems.
I have tried the following to fix any potential battery drain issues:
- Performed a factory reset
- Turned off location services when I'm not using a navigation app
- Disabled Google Currents
- Uninstalled Facebook
So far my Nexus 4 seems fine, and I haven't had the need to bring it out of deep hibernation mode lately. Hopefully you'll be able to revive yours. If you do, perhaps you can try what I did to keep your Nexus 4 in working order.
However since I bought it in July 2013 it has locked up on me 5 times, three of which were due to drained battery and the other two at 50% or greater charge.
