Hi, nice to meet you. First i want to say that i'm not good at English because i'm Korean, so just ignore grammatical mistakes.
Because i leave in Korea i had to order my phone from the Korean google play store and EXPANSYS? company bought for me.
My N4 came this tuesday and i was so looking forward to using it. so i booted up the phone as i opened the package i entered my google account and set up my wifi.
after that i found that my n4's softkey (the back button) didn't exist.... and it started to freeze.
so i found my phone keep rebooting>>>(google logo>>nexus logo>>vibrate>>google logo........./repeat)
i even tried factory reset but it just helped my phone to resist longer... what i mean is that my phone works well if i just leave my phone after 5hours but it restarts again if i use it for a longtime and i need to factory reset my phone again and again.Also even there are no freezes if i shutdown my phone and try to reboot the same problem appears
>>because of this phenomenon i don't think it's a hardware or bad battery.)
So what i want to ask you is that will my phone get better if i open my backcover with my driver and do the same thing as the solution of the red led problem?) i even used the toolkit 2.0.0 version to restore my phone but it didn't work.
what shoud i do? ㅠㅠ
it's hard for replacement or fixing caus there is just one factory which fix myN4.....(GOD DAMN LG)
I hope you understand my bad English and i want you guys to know that i'm really desperate.
what shoud i do? ㅠㅠ
