Originally Posted by
Mark Reed3 My Nexus 4 has been running hot since the upgrade to Lollipop 5.0. The battery has finally failed and the phone will not start. Has anyone had a similar problem. Is there an easy fix? You would have thought Google would have tested this before hardware starts failing. Will Google take any responsibility for the failure?
Were you still having this problem? After the 5.0.1 update I received via OTA yesterday my phone is running very hot. I flashed it back to 5.0 and it is still hot. Please let me know if you found a fix for this or if we need a new battery. Thanks
