1. AC Question's Avatar
    when my phone is connected to wifi my signal is fine i can call etc. when i turn my wifi off the signal bar has a exclamation mark and when i go out theres no signal?
    Talktalk
    Nexus 4
    Android 5.0.1
    03-31-2015 04:53 PM
  2. belodion's Avatar
    Welcome to the forums.😃
    Has it always been like this? Do you know what the signal is like in your area, for your network?
    It may simply be that the phone is failing to connect. Turning Airplane Mode on and off, and Mobile Data off and on, sometimes fixes it.
    03-31-2015 05:20 PM
  3. Tony_H's Avatar
    I have the same problem.
    When I am away from WiFi the phone signal always has an exclamation mark by it and the Chrome browser refuses to connect to the internet but strangely some other apps like OneDrive, BBC weather will connect. I was told that if the Android system thinks there is WiFi available that this will happen but I have no idea how to over-ride the problem to get a connection when there obviously isn't a WiFi signal.
    I have tried switching WiFi on and off, re-booting the phone, turning data roaming on and off, turning aeroplane mode on and off, checking and trying new TalkTalk settings for the mobile connection all to no avail. I should add that it worked fine before it updated but I have no idea which Android update caused the problem.
    My phone is a OnePlus One with v6.01
    Do let me know if you find a fix!
    07-08-2016 04:33 AM
  1. What is this new WIFI icon on my task bar?
    Last Post: 04-09-2015, 06:14 AM
  2. Replies: 1
    Last Post: 03-31-2015, 05:41 PM
  3. How do I get my phone paired to play music?
    Last Post: 03-31-2015, 04:57 PM
  4. Replies: 1
    Last Post: 03-31-2015, 04:42 PM
  5. trying to delete aol from my android phone
    Last Post: 03-31-2015, 04:17 PM
