I switched from Dalvik to ART cache...holy crap. Apps start way faster now. They seem to work faster too...switching between pictures in the gallery is smoother and faster than before.
To enable it, activate developer mode by goting to Settings then "About Phone" and tapping on the build number really fast until it tells you developer mode is enabled (at least 7 taps...it will remember this when you reboot too, so you only have to do it once). Go to "Developer options" that now appears in the Settings menu. Click on "select runtime" and choose ART. You can swap back later if you want.
It will re-start and will re-compile your apps or something. Took about 15 minutes for me.
I am a pretty advanced user but not an expert...does anyone know if there are downsides to using ART right now?
