1. Gaurav's Avatar
    Man this would be my ideal accessory if some one out there would be interested in making it! Basically my wish is for a battery case like various options that exist for other devices but also with an integrated microSD slot. I imagine something that combines the sleekness of the powerskin sled but also has a ability to read microsd or minusb like the kickstarter link below:
    Nexus 5 battery case - Page 2 - xda-developers
    Mini MicroSD Reader for Android Smartphones & Tablets by Andy & Rich — Kickstarter
    Anyone else interested in something like this?
    11-16-2013 04:31 PM
  2. tech_head's Avatar
    So while it might work fine you would need a switch or install a custom kernel.
    Normally when USB-OTG is active, the phone won't charge.
    On the Nexus 7 you had to run a custom kernel after unlocking the kernel to charge and have the USB-OTG function at the same time.
    It is possible to have a switch to chose which function.
    You only need to remember to unmount the memory before selecting the switch.
    11-20-2013 07:02 PM
  3. Ethan Grimes's Avatar
    Could integrate an nfc chip that launches a dedicated app that automatically switches it when done using the card.
    11-22-2013 03:04 PM
  1. How to retrieve an offline map in Google Maps?
    By Concoran in forum Legacy Android & Other OS's
    Last Post: 02-05-2014, 03:31 AM
  2. Replies: 5
    Last Post: 11-19-2013, 12:31 PM
  3. Do you guys transfer your apps to SD Card?
    By hell911 in forum General News & Discussion
    Last Post: 11-17-2013, 09:00 PM
  4. Battery Life...where'd it go?
    By BrianCioffi in forum Sprint Samsung Galaxy Note 3
    Last Post: 11-17-2013, 08:29 PM
  5. Battery test result
    By tbgjlb in forum Google Nexus 5
    Last Post: 11-16-2013, 04:07 PM
