Ok, So I bought one of these things. Ordering was easy, and it was $15 including shipping. Shipping was quick.
Buy here: http://www.meenova.com/st/sp_m3r.html
Not much to it...you plug it in and it works. No special drivers to install. Just installed Total Commander and the USB Stick plug-in. The phone recognizes it without reboot. Insert the SD card into the reader, plug the reader into the phone, and you're done.
Total Commander is just a file manager like Astro. It is nothing special at all, but is the only one I know of that will read external SD like this. It's free.
https://forums.androidcentral.com/e...ghisler.android.TotalCommander&token=iTFsKd8v
You will need to install this app as well (also free):
https://forums.androidcentral.com/e...=de.hechler.tcplugins.usbstick&token=oQozd1Sh
Nothing else special needed. Once these are installed, just open total commander and click on the USB Stick icon. You can copy/paste files to and from the reader at will.
SD Card slides in horizontally on the top.
