Nexus 5: Flashing red light
mamartin89
84
Does anyone else's Nexus 5 LED light flash red while being charged and the screen is off?
Just wondering because mine is doing it and I don't remember if it's new or something it has always done.
Thanks!
Posted from my Nexus 5 via Android Central App
steven0188
22
Re: Flashing red light
If I remember correctly, the LED light does flash red when the phone is charging, I myself downloaded Light Flow, which allows you to manage all aspects of the LED light, I like it much better than not having control over it
Sent from my Nexus 5 using Tapatalk
patruns
3,192
59
48
I'm charging mine now and I don't see any flashing light. How often is it flashing?
mamartin89
84
Constantly o_0 I wasn't sure if I remember it doing it before or not. I wonder what it means. My phone seems to be working as normal. It's kinda strange and has me worried.
Robbie317
2,752
12
Mine doesn't flash while charging????? I get different color flashes for email, text, tweets and what not but nothing while charging..
mamartin89
84
I'm thinking of might mean something is going wrong, but I haven't noticed any changes. I do not have light flow on my phone either so I know it's not that. I'll keep an eye on it. I will call Google and ask what it means. I hope my phone isn't about to die. I've had it for such a short time.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Mine doesn't flash when charging either - only when a notification is unchecked, which could also happen when the device is charging. But the act of charging alone does not trigger the LED.
N4Newbie
Trusted Member
Nov 15, 2012
5,006
If you could clarify: do you mean the screen is simply off or the phone is in"power off" mode? (Long press power button then select Power Off from the menu)
mamartin89
84
What setting do you have turned on? Perhaps I have mine turned on and didn't know.
patruns
3,192
59
48
It's the SportsCenter app. It flashes red when there is a sports update.
What leads you to believe he has that app installed? I am sure there are a number of apps available that might flash an LED red.
mamartin89
84
My guess is the battery is under 15% in this case.
Nope, it flashes no matter what percentage the battery is at. Idk what is making it happen, but my phone is working properly so I guess I'll just live with it. Lol
Sarah Silva1
Hi, that happened to me while phone was dead. flashing light was on bottom where the charger plugs up. it changed my background image. wtf! :(:(
rickms80
402
My Nexus 4 would flash red while charging when the battery was too low to power the phone. My phone had died over night.
If I had to guess this may be an indicator that there is a battery problem. My Nexus 5 does not flash red while charging.
Jan
