anon(8256055)
So can we assume its running 5ghz and ac?
Router has dual band, and all protocols. I'm basing my sustained download speeds by the process of downloading 4+GB HD movies. Not just basing on speed test apps.
iku04108
Try running your speed test at some other place like a Starbucks since they always have a pretty good Wi-Fi. If you get the same slower issues at two or three places then it pretty much proves it is the Nexus 5 and not your router. Then you should just get it RMA.
Folks,
Tonight I read that turning off mobile data and WiFi and then switching on WiFi on its on might be a fix.
Something to do with a power saving mode.
I have tried this and so far so good.
I will keep you posted.
Kyle
Nope, doesn't work for me
Test 1. wifi and data on
Speedtest.net by Ookla - My Results
Test 2. data off, wifi on
Test 3. turned off wifi and turned it back on. data is still off
These speeds are horrible. Sometimes I get up to I believe 5mbps. But signal is going through 3-4, may be 5 walls.
If I get upstarts, where router is, I'll get like 15mbps behind 2-3 walls.
It's just weird how same obstructions differently affect performance on these devices. that's why I suspect the N5 wifi receiver is under-powered.
And as I mentioned a few times already - same issue with hotspots. Download speeds may be much faster than these, but still much slower than on Nokia 521 and GS3
P.S. By the way, I'm assuming you turning mobile data off one of the two ways (which seem to do the same thing) -
From the home screen, tap the All Apps icon.
Scroll to and tap Settings.
1. Tap Data usage
2. Toggle Mobile data to OFF
---OR---
1. Tap More.
2. Tap Mobile networks.
3. Tap to check or uncheck Data enabled.
