How van I permanently know battery's percentage?
http://www.droid-life.com/2013/11/1...ttery-percentage-monitoring-no-root-required/
Sent from my Nexus 5 using Tapatalk
Use battery widget reborn best app out I think.
It's better than nothing but you can't really see the reading until you're down below 45% or so. I'd like to find a better alternative as well. Don't like using the Battery Doctor one because it just doesn't look clean.What about Battery Percentage for KitKat, develoled by XDA Developer?
Now it's clear. I just wondered how to show percentage in the notification bar.Sure it does. Pull down from the top of the screen with one finger and tap the icon at top right of screen, or pull down with two fingers simultaneously. Either way, you should see:
you can use power toggles... its an all in one solution for Toggles and battery percentageNow it's clear. I just wondered how to show percentage in the notification bar.
