01-27-2020 02:50 PM
53 123
tools
  1. ElanaA's Avatar
    Magnet worked perfectly on my HTC. I'm so happy I read this because I was planning on buying a new phone because of this issue. Didn't even have to glue the magnet in place. I just attached it and put the cover back on and it holds it in place.
    Thanks!!
    02-23-2019 11:57 AM
  2. MUsman1's Avatar
    Solved!!! Solved!!!!!
    Ok i had the same problem and tried every software solution i could think of, then i realized that it is a hardware problem so before i bought a new camera i did this. Dont ask me what made me think of it but this is just how my brain works. While the camera app was open and it was buzzing all around ,i took a tiny ,tiny neodymium magnet and put it near the main camera opening on the rear and all of a sudden the buzzing and shaking stopped. So i put a little drop of ca glue to hold it in place and now its fixed, well sort of, at least temporarily till i can buy a new camera assembly. I was trying to think of why this fixed the issue but im kind of burnt out right now, any help is always appreciated.
    It worked, you are a genius!
    I did the same and it's working perfectly fine for me. You can use the magnet in the broken handsfree.
    03-10-2019 03:53 AM
  3. Hasan Moursi's Avatar
    Thank you very much.
    You saved my huawei g8 camera by this genius idea.
    01-27-2020 02:50 PM
53 123
  1. SM-G900H (Exynos) users - Do any 64GB cards work for you?
    By 1AvgUser in forum Samsung Galaxy S5
    Last Post: 06-09-2014, 05:13 PM
  2. how does the notifications work...
    By iamdustin24 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-08-2014, 01:50 AM
  3. Replies: 1
    Last Post: 05-06-2014, 11:56 PM
  4. Google Calendar is not Syncing.
    By mawil1013 in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-06-2014, 09:46 PM
