Wireless charge with USB OTG
cwright3
I bought all the gear for this setup assuming that it would be a good workaround for freeing up the USB port for storage, but of course this doesn't seem to be supported either. I bought a wireless charger for the car and the Meenova MicroSD card adapter, but I can't get both to work at the same time. With both the car wireless charger and one I have at home, they work perfectly fine until I plug in the Meenova adapter, and then it stops charging until I remove it.
I've looked everywhere for solutions to this or a custom ROM but have had no luck so far. Most threads I come across are about doing this with a USB Y cable instead of wireless charging though - and I even saw one person on an old thread recommend a wireless charger as the workaround, but it's definitely not working for me.
Is there an obvious fix I'm missing? Or is this not intended to work either?
Thanks for your help.
Non
