Are power banks safe to use for charging purpose??? Do we need to consider any particular charger with specific power output? Any specific brand to consider?
The phone determines how fast it takes a charge. I have used many tablet and phone chargers interchangeably, and have never seen any damage.Are power banks safe to use for charging purpose??? Do we need to consider any particular charger with specific power output? Any specific brand to consider?
I must say that High amp chargers for sure will kill you device battery like using a charger for ipod for charging you iphone.Trust me I had to change the battery and after the phone broked because of the high amp charging about a year.Use Original Chargers only and when using a power bank make sure it is compatible with your device
Please don't trust Dragoiopinion's post... this is inaccurateI must say that High amp chargers for sure will kill you device battery like using a charger for ipod for charging you iphone.Trust me I had to change the battery and after the phone broked because of the high amp charging about a year.Use Original Chargers only and when using a power bank make sure it is compatible with your device
High amp chargers won't damage the phone but they won't all charge fast. If the phone battery stats page says charging AC that's the fastest it gets. But if it says USB than the charger isn't really compatible and it won't charge at the quickest rate it could.
My LuguLake 6000mAh powerbank with wireless Qi charges as fast as plugging it into the wall with the original charger.
To clarify this, if it says USB then the charger and/or the micro-USB cable connecting your phone to it aren't really compatible. Not all Micro-USB cables are the same in the way they're configured.
<3 my LuguLake Qi charger, and agree 100%.
