Galaxy Note 10 Deal: BOGO at Verizon!
  1. ianhanson85's Avatar
    Anyone have an idea what is causing this? I literally have done nothing with my phone since removing it from the charger this morning. Its been idle.... I don't think I should have burned through 8% battery while on standby... I wiped the cache partition yesterday too.
    09-23-2014 10:09 AM
  2. ianhanson85's Avatar
    Attached screen shot.
    09-23-2014 10:11 AM
  3. surrealjam's Avatar
    What setting do you have against:
    Settings > Location > Google Location Reporting > Location Reporting
    On or off?
    09-23-2014 10:13 AM
  4. B. Diddy's Avatar
    You only have one bar of reception--maybe it has more to do with poor signal? Tap Cell Standby and see how much Time Without Signal there is? Or tap the graph, and look at the Mobile Signal graph--is there a lot of red or yellow?
    09-23-2014 10:25 AM
  5. ianhanson85's Avatar
    On or off?
    Off
    09-23-2014 10:26 AM
  6. surrealjam's Avatar
    Although I generally agree, poor signal strength doesn't seem to affect battery so much when you have a good WiFi connection (which it appears the user does). At home, I only get 1 bar of mobile reception but standby is very similar as at work where I get full bars.
    tonyr6 likes this.
    09-23-2014 10:28 AM
  7. surrealjam's Avatar
    Off
    As crazy as it sounds, can you try to enable it? I had a very similar issue with Android OS and WiFi taking up large chunks of battery and enabling location reporting actually helped. I appreciate this is not how it should be but I presume there is a potential bug somewhere.
    09-23-2014 10:30 AM
  8. ianhanson85's Avatar
    09-23-2014 10:36 AM
  9. ianhanson85's Avatar
    Its worth a try at this point. Anything to improve standby time. I love the nexus and android but am coming from an iphone which has excellent standby time.
    09-23-2014 10:39 AM
  10. B. Diddy's Avatar
    That's interesting--I think it still impacts me. There are areas in the hospital where I work where signal is pretty abysmal, so if I'm hanging out there a lot, my battery usually takes a hit. Wi-fi is on, and the wi-fi signal is good as well--but the cell signal is lousy. I keep mobile data off while at work.
    09-23-2014 10:40 AM
  11. B. Diddy's Avatar
    27% Time Without Signal is pretty significant. That's almost an hour where the cell radio is working harder to find signal. And that 27% figure doesn't include weak signal--only no signal.
    As an experiment, see what the battery drain from 100% is like over the same time period in an area of good reception.
    chezm and crxssi like this.
    09-23-2014 10:41 AM
  12. surrealjam's Avatar
    I also think this is interesting It goes to show how two seemingly similar scenarios can be actually quite different... so many variables I suppose.
    09-23-2014 10:42 AM
  13. B. Diddy's Avatar
    That's for sure! In your situation, are you getting that much Time without Signal as well? The difference for you may be that although your signal is weak, it might also be consistent and without dropout. ianhanson85 might be having more signal dropout than you, which means more battery drain.
    09-23-2014 10:45 AM
  14. surrealjam's Avatar
    Yes, it is consistently poor without drops so I take your point that time without signal is different.
    B. Diddy likes this.
    09-23-2014 10:47 AM
  15. ianhanson85's Avatar
    Is there a solution to this? I do need to be able to make and receive calls throughout the day. Thanks.
    09-23-2014 10:54 AM
  16. calicocat2010's Avatar
    Could be an app causing your battery to drain. This HAPPENED in mine with my new Note 3 that I bought Sun. I had to delete a bunch and now my battery is doing just fine whereas YESTERDAY my battery drained in 5 HOURS.
    09-23-2014 11:52 AM
  17. Javier P's Avatar
    I don't think there's much you can do about that. I spend most weekends and holidays in a place with a weak signal (not as bad as yours) and I see a difference in battery life.
    Try to keep mobile data manually off and look for a "hot spot" where reception is better.
    09-23-2014 12:59 PM
  18. B. Diddy's Avatar
    Which wireless provider do you use? You could inquire about a cell signal booster, which might be free. I have T-Mobile, and they allow people on Simple Choice plans to have one free.
    09-23-2014 01:41 PM
  19. ianhanson85's Avatar
    Sprint
    09-23-2014 01:46 PM
  20. B. Diddy's Avatar
    Their signal booster is the Airave, and I think it's free for you to use. You probably have to put a deposit down. Call Sprint and ask them.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    09-23-2014 02:22 PM
  21. 2232987's Avatar
    I have a Note 3 that's about a year old and has had excellent battery life. For the last 3 or 4 days something has been sucking it dry. The screen used to be the biggest battery hog, now it is Android OS at a whopping 60%. Something has changed, or something is stuck, or... ?
    11-08-2014 08:18 PM
  22. B. Diddy's Avatar
    Welcome to Android Central! You're better off posting your question in the Note 3 forum. This is the Nexus 5 forum. Samsung Galaxy Note 3 - Android Forums at AndroidCentral.com
    11-09-2014 12:56 AM
  1. Battery drain fixed!!!!!! Gs5
    By Ian Bennett in forum Samsung Galaxy S5
    Last Post: 02-20-2017, 06:14 PM
  2. Note 3 - Android System - Battery Drain
    By Sweeet1102 in forum Samsung Galaxy Note 3
    Last Post: 09-24-2014, 10:12 AM
  3. android contacts
    Last Post: 09-23-2014, 11:02 AM
  4. Battery Life - Dependent on Selected Watch Face?
    Last Post: 09-23-2014, 10:03 AM
  5. Replies: 2
    Last Post: 09-23-2014, 09:08 AM
