1. GK2's Avatar
    Hello, I am new to these forums. I am desperately seeking help, as I don't want to pay to get this phone fixed.
    I bought a used nexus 5 that worked fine up until recently. It came unlocked and rooted. I believe I lost the root when I updated to android 4.4.2. Since that upgrade, I have received only error messages when trying to update to 4.4.3. I then noticed I couldn't connect to the game center for games, or download files from the net. This was a persistent problem so I decided to factory reset the phone using the nexus root toolkit. The phone has now been manually upgraded to 4.4.4.
    I tried returning it to stock using the nexus toolkit (flash stock and unroot, followed by oem lock), and have since unlocked and rooted. The thing is now, in both oem state and rooted, the phone will not connect to anything. The only thing is is capable of doing is phone calls and texts. NOTHING else works. Chrome wont connect (proxy error), play store won't connect, google now won't connect either(sign-in error).
    Needles to say this is tremendously frustrating. If a factory reset won't work, I have no idea what is wrong. I am no very tech savvy with cell phones. Is it android 4.4.4. causing the problems?
    Any help or suggestion is greatly appreciated.
    10-01-2014 01:14 PM
  2. p3ntyne's Avatar
    Under WiFi settings, hold your network and tap 'Modify Network'. Next, tap advanced options and ensure the proxy is set to none.
    Hope it helps
    belodion likes this.
    10-02-2014 03:03 AM
  3. GK2's Avatar
    Great!! Its working now, ty for your expertise.
    p3ntyne likes this.
    10-02-2014 12:28 PM
  4. belodion's Avatar
    Hope it helps
    Very impressive diagnosis, if I may say so. ☺
    p3ntyne likes this.
    10-03-2014 09:57 PM
  5. p3ntyne's Avatar
    Awesome, glad to hear it!
    Thanks
    10-04-2014 03:38 AM
  1. My VuTalk is not working. What should I do?
    Last Post: 01-28-2015, 01:18 PM
  2. Nexus 5 auto lock screen
    By alighasempoor in forum Google Nexus 5
    Last Post: 11-20-2014, 01:16 AM
  3. Can I get some rooting help for my Samsung Galaxy S4?
    By Rocio Vallejo in forum Samsung Galaxy S4
    Last Post: 10-02-2014, 05:05 AM
  4. Why is WiFi is using battery when it's turned off?
    Last Post: 10-01-2014, 01:20 PM
  5. How do I get email working on my Nexus 5?
