1. Binghambloke's Avatar
    Hi
    I have been trying to find an answer to this for a couple of months now with no joy so hoping someone on here knows the answer please.
    I had been using Waze on my Nexus 5 with output through the phone speaker and it was great.
    Very occasionally I would swap to use it through my car's bluetooth.
    Now I am using it through phone speaker and whilst driving you can not hear it as it's so quiet.
    The slider is up full.
    Even when adjusting the master Music, video, games & other media volume bar to full it has no change.
    Any ideas please?
    I love Waze and has been far better than my TomTom standalone unit I had with the RDS traffic so would love to be able to hear it again.
    Thanks
    10-07-2014 05:01 AM
  2. Jeremy8000's Avatar
    I use Waze daily on my N5 and haven't noticed any issues... Is it impacting any other apps? If not, you might try uninstalling and reinstalling it to see if that resolves the issue.
    10-07-2014 09:48 AM
  3. Binghambloke's Avatar
    Other apps are fine such as Spotify and YouTube.
    I have uninstalled and reinstalled but still the same
    10-07-2014 09:58 AM
  4. flipped4dinc's Avatar
    You could transfer the audio to a bluetooth headset. Works great.
    10-07-2014 12:23 PM
  5. Benjamin_NYC's Avatar
    Then you have to be a BT headset *****.
    10-09-2014 06:43 AM
  6. JJones021's Avatar
    I have a Nexus 5 and had the same issue.
    - Go to your settings
    - Choose sound near the bottom
    - Make sure the SPEAKER VOLUME IS "NOT" CHECKED.
    Hope this helps 😎
    04-25-2016 05:43 AM
  7. droriavi's Avatar
    waze speaker very low on my lg3 unit.
    Avi Drori
    05-04-2016 10:40 AM
  8. Tobin Schuster's Avatar
    I finally found a solution for the low volume on the Waze voice. The volume is driven by the phone speaker volume. Make a phone call and put the phone on speaker. Turn the volume all of the way up and then hang up the phone. Waze volume will now work.
    08-27-2016 10:21 PM
  9. Hellfire_s6s's Avatar
    Waze is doing the same thing on my Droid turbo, and the volume is also getting stuck on high. It seems ok for the first minute alot of times but then gets stuck on either low or high volume and I have to adjust the volume in the Waze settings. I hope there's a way to fix it.
    08-31-2016 07:03 PM
  10. Antoine Laguna's Avatar
    @JJones021
    Thanks a lot. I checked solutions to this problem on internet for some hours. Most of the solutions requested me to install third party apps. It was not logic to me. Your answer resolve the problem. It should be included in waze help.
    02-08-2017 03:45 AM
  11. Goodness Gracious Me's Avatar
    Well done, thank you Tobin. A straightforward, logical solution and it works!!
    07-14-2017 06:51 PM
  1. Can I retrieve a lost camera folder on my Note 3?
    Last Post: 10-07-2014, 08:52 AM
  2. Can I stop the ringtone volume from adjusting?
    Last Post: 10-07-2014, 04:46 AM
  3. Replies: 0
    Last Post: 10-07-2014, 04:30 AM
  4. motorola moto g from walmart on verizon
    Last Post: 10-07-2014, 03:59 AM
