1. mvasquez009's Avatar
    I'm noticing some battery drain during the night on my nexus 5 even when my phone is in airplane mode.. I charged it to 100 then took it off the charger and turned airplane mode on. When I woke up it was at 95 percent.. I know it's not a huge chunk of battery but isn't that still bad for it being in airplane which is supposed to turn off all the radios? I could of swore when I did this last week it only dropped one percent, why the sudden jump? And Google play services was the top thing draining battery according to my phone stat settings.. Any advice would be awesome! Is my battery starting to die?
    10-25-2014 10:37 AM
  2. Gekko's Avatar
    the battery % is not linear and not really 100% accurate - it's a rough estimate - so don't get too fixated and obsessed on the exact percentages. also the Android OS/Device will stop charging at 100% in order to protect the device/battery and will only restart charging after it loses a few % so it may not be at 100% when you take it off the charger.
    10-25-2014 10:50 AM
  3. Benjamin_NYC's Avatar
    Is this a joke?
    10-25-2014 11:56 AM
  4. srkmagnus's Avatar
    I don't see nothing wrong with that battery usage overnight. Keep in mind that there are still other processes running in the background, which explains the 5% drain. If you are worried about drain, but want to keep calls coming in, disable mobile data. It should yield about the same battery saving overnight.
    10-25-2014 06:25 PM
  1. Favorite Application For Listening To Music On SD Card?
    By Dankees in forum Samsung Galaxy Note 4
    Last Post: 10-26-2014, 09:36 AM
  2. Replies: 1
    Last Post: 10-26-2014, 01:58 AM
  3. Replies: 2
    Last Post: 10-26-2014, 01:56 AM
  4. Replies: 1
    Last Post: 10-25-2014, 03:05 PM
  5. Why isn't my touch screen responding since 4.4.2 upgrade on my Tab 3?
    By gajp01 in forum Legacy Android & Other OS's
    Last Post: 10-25-2014, 11:23 AM
