1. CARLITOS_M's Avatar
    Since I upgrade to Android 5.0 Lollipop have these problems while my phone is charging:
    1- The background (I choose in my picture album) dissapears for the default Android 5.0 background.
    2- When I push the right side button the screens go on and off.
    3- If I get a call, the phone rings and/or vibrates put I can't see who's calling unless I unplug the phone from the USB cable.
    Is there other people with the same problems? If yes have found a solution?
    11-19-2014 03:17 PM
  2. chezm's Avatar
    have not experienced any of those, try wiping cache partition...i wiped/formatted before proceeding with Lollipop and mine has worked flawless (except for App specific issues).
    11-19-2014 03:41 PM
  3. B. Diddy's Avatar
    Welcome to Android Central!
    Do you mean that after you select a photo from your picture album to be the wallpaper, it stops being the wallpaper after some time?
    Do you mean the Power button? How does the screen go on and off--is it flickering? Obviously, the Power button will cause the screen to sleep, then come back on if you press it. Can you clarify?
    11-20-2014 02:14 AM
  4. CARLITOS_M's Avatar
    B. Diddy:
    Yes my screen is flickering when I push the Power button.
    Exactly the picture I chose from my album to be my wallpaper stop being the wallpaper after a while.
    Chezm:
    Didn't you loose everything you had by formatting?
    Since I already installed Lollipop will I get a second notification to install it if I format the cellphone
    11-20-2014 07:42 AM
  5. jj14x's Avatar
    Wiping the cache partition in recovery is not a factory reset - it will not wipe data or your OS.
    Also, since you have already installed Lollipop, even if you did a factory reset, it won't get rid of Lollipop - it will give you a brand new clean install of Lollipop (you won't go back to kitkat). You will lose data of course with a factory reset.
    B. Diddy likes this.
    11-20-2014 08:13 AM
  6. belodion's Avatar
    Also, if it reassures you, I wiped the Cache Partition shortly before, and soon after, the update....I understand that some regard this as good practice. Whether it is I don't know for a fact, but even if it does no good, it certainly seems to do no harm.
    11-20-2014 08:30 AM
  7. B. Diddy's Avatar
    Those are odd bugs, and I agree that it won't hurt to try the cache partition wipe. Just be aware that it takes 5-10 minutes, so just be patient and let it run: http://forums.androidcentral.com/nex...-recovery.html
    11-20-2014 11:21 AM
  8. CARLITOS_M's Avatar
    Just wiped/reboot my phone ans still have the same problem I believe it may be one of the apps I have that causes this.
    11-20-2014 04:05 PM
  9. CARLITOS_M's Avatar
    I finally found the problem. It seems that if the default language is set to French (Canada), Android 5.0 doesn't work properly
    Thanks to everyone for the help
    11-21-2014 06:49 AM
  10. B. Diddy's Avatar
    It's hard to believe that the wrong system language would have led to the problems you mentioned in your original post, though. Still, glad to hear things are working better!
    11-21-2014 11:29 AM
  1. Can AT&T GoPhones be used out of the box on Cricket?
    By jdbii in forum Other US Carriers
    Last Post: 02-01-2015, 10:31 PM
  2. Mark on the screen from scrolling?
    By punk999 in forum Samsung Galaxy S5
    Last Post: 11-19-2014, 09:42 PM
  3. Replies: 1
    Last Post: 11-19-2014, 03:58 PM
  4. Why does my Moto G (4G LTE) prioritize mobile over wifi when wifi is available?
    By joeschmoeblahblahACacct in forum Ask a Question
    Last Post: 11-19-2014, 03:06 PM
  5. So I got my ota but not really
    By MaxxMoss in forum Android 5.0 Lollipop
    Last Post: 11-19-2014, 03:04 PM
