1. anon(4110434)'s Avatar
    Attached Thumbnails Nexus 5 battery percentage-87c5c93d8470807d8ed9a58aea3f67a3.jpg
    11-21-2014 07:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! My guess is that it has to do with a change in how the battery info is accessed in Lollipop. The battery widget that you installed probably isn't compatible yet. Try emailing the developer of that widget and ask if there are any Lollipop compatibility issues.
    11-22-2014 12:11 AM
  3. camanokid's Avatar
    Lockscreen widgets are gone with LP.
    Alerts now show on lockscreen.
    Find a battery app with alerts!
    I use Battery by MacroPinch.
    Go to Settings/Notifiations ON.
    anon(4110434) likes this.
    11-22-2014 10:37 AM
  4. vividrich's Avatar
    "battery percent for kitkat /L" will enable percentage visible in the existing battery icon.
    Posted from my Nexus 7 2013 via Android Central App
    11-22-2014 10:41 AM
  5. anon(4110434)'s Avatar
    11-22-2014 07:02 PM
  1. note 3 bad battery life
    By masaga91 in forum Samsung Galaxy Note 3
    Last Post: 11-23-2014, 08:18 AM
  2. battery life
    By The Boston Strangler in forum Google Nexus 6
    Last Post: 11-22-2014, 02:28 PM
  3. Battery % without bringing down quick settings?
    By garrim85 in forum Google Nexus 6
    Last Post: 11-22-2014, 01:25 PM
  4. Size of Straight Talk SIM for Nexus 5
    By David Lessnau in forum Google Nexus 5
    Last Post: 11-21-2014, 10:34 PM
  5. Excessive Battery Drain
    By Nuno Leonardo in forum Sony Xperia Z1 Compact
    Last Post: 11-21-2014, 03:55 PM
