It's probably doing "operating system stuff", the communicating it needs to set itself up.
First thing you do when you get an update is clear the system cache. Then you keep your eye on the battery for a week, so it doesn't drain too far when you're not looking. If it doesn't settle down in about a week, go to your carrier's store and see what they can do for you. (One little glitch in an OTA update can cause a problem like that, and they can reflash the update.)
BTW, Wifi Active doesn't mean "Wifi in use", it means it's awake. (It indicates that you have wifi set to never turn off during sleep - which is the right way. It's on a lot [constantly], but it's not consuming a lot of power just being on.) The fact that it's consuming as much as 41 minutes of screen on-time means that a lot was being transferred, which is normal for a new ROM or update for about a week.
48% use in 17-1/2 hours means about 35 hours of use until the battery is dead (which you should never allow - 40% is about "last warning" to charge the phone), which isn't terrible.
