1. Sarah Maystock's Avatar
    I just recently fixed this same issue with my Nexus 7, but this is a whole different beast. I used Check My Android to check my accelerometers, and they are functioning just fine. I cleared my cache and then cleared/reformatted the partition. Then I did a factory reset because I was losing my mind. It's still not working. I went into the display settings to turn on the auto rotate manually and it will rotate with that screen up but not on my home screen or in any other app. What the actual hell. What am I supposed to do now?
    09-29-2015 04:30 PM
  2. belodion's Avatar
    Welcome to the Nexus 5 forum.
    Have you tried Safe Mode?
    09-30-2015 10:02 AM
  1. Replies: 6
    Last Post: 10-13-2015, 05:20 PM
  2. Can you help me turn on my tablet?
    Last Post: 09-29-2015, 04:55 PM
  3. Replies: 0
    Last Post: 09-29-2015, 04:28 PM
  4. Replies: 1
    Last Post: 09-29-2015, 04:14 PM
