1. AC Question's Avatar
    Hi Guys,
    I have google nexus 5 32gb and recently i my phone has started behaving very weird. My phone batter died and it switched off and after a few moments when i reached home i plugged in a charger and my phone wont show me charging sign nor it will turn up so i left it on charge for a couple of hours and returned to try the same switching on method and still it wont turn on. So started googling this problem and i came across a forum where it showed me to hard booth by pressing the volume down and power button. Magically it did not work for me so i made an appoint to go and see LG Service Store and suddenly my phone turned on so i thought the problem was solved untill it happened again and again and again so now if my phone switches off i am not very sure if it would turn back on. As this is a very random problem and i am unable to solve it while the phone is on and if i charge it before the battery reaches the critical levels and shuts on its own i am just fine.
    What can be the issue as battery works the whole day of medium to low use and also other hardware happens to function well without any hanging complaints. Also my phone randomly switches off if i am playing some game as it gets heated and the same story of phone not booting.
    please if anyone can solve this for me it would be great..
    Thanks
    11-02-2015 06:13 AM
  2. belodion's Avatar
    Welcome.
    I think it might be best to make that appointment again. It sounds like some internal fault which you could probably not fix easily yourself.
    11-02-2015 08:12 AM
  3. Jonneh's Avatar
    I agree, it sounds like something is wrong internally. Perhaps liquid damage? Motherboard damage? It shouldn't be heating up and shutting itself off during use, even if it's heavy use.
    Take it to a phone fixing store like uBreakiFix, Fondoctor, Solaris, etc.
    I don't know about the others, but at ubreakifix they do a free diagnostic first. So they'll take your phone in and see what's wrong before charging anything.
    11-03-2015 12:17 AM
  4. DharamK's Avatar
    I have taken an appt. with official LG service center and will post the progress.
    Thanks
    11-03-2015 04:41 AM
  5. Jonneh's Avatar
    Thanks
    Sounds good!
    11-03-2015 05:39 PM
  1. battery
    By ansa82 in forum LG V10
    Last Post: 11-02-2015, 03:08 PM
  2. Why isn't the camera of my HTC Desire X starting up?
    By AC Question in forum HTC Desire X
    Last Post: 11-02-2015, 12:39 PM
  3. How can I disable earphones on a Samsung Galaxy S4 mini?
    By AC Question in forum Samsung Galaxy S4 Mini
    Last Post: 11-02-2015, 12:36 PM
  4. Replies: 1
    Last Post: 11-02-2015, 08:41 AM
