A
AC Question
problems with data transferring for the first time
Hi:
I usually connect nexus 5 to my laptop, and works fine. I have done it a thousand times.
Now, it does not work anymore. The icon of Nexus appears at the explorer, but nothing inside.
I have tried to connect it to my mac. I have downloaded the application for transferring the files, but then there is a message: "if your screen is locked, unlock it and try again". My screen is not locked, but again the message.
What is going on?
Hi:
What is going on?
