1. noambason's Avatar
    Yo guys, how's it going?
    I'm having a very frustrated issue with my Nexus 5 d820.
    The battery indicator suddenly started to stuck -for days- on random numbers like 93%, 88% but most of the time it's stuck on 100%.
    It does recognizes that I'm charging, but the values aren't changing.
    Things I've tried:
    Complete drain, complete charge.
    Replacing the Battery.
    Wipe to Factory / Wipe Cache
    Install a brand new rom using fastboot
    Install TWRP, Root
    Replace the kernel to elementalx
    What else can it be? is there an hardware part which is in charge of the battery indicator which I can replace?
    Thank's in advance.
    01-08-2016 05:08 AM
  2. belodion's Avatar
    Welcome to Android Central.
    Have you tried installing another battery monitor, for example GSam? If so, does it indicate the correct percentage in the status bar top left?
    01-08-2016 03:30 PM
  3. Rukbat's Avatar
    It could be either a hardware or system problem (the percentage indication is a combination of both), but unless you're going to fix it yourself, it could get expensive.
    The first thing I'd do is what Belodion suggests.
    If that doesn't give you a proper indication, I'd back up all apps and data, then reflash the ROM. If that fixes it, it was a system problem. (And fixing it costs nothing but time.)
    The next thing I'd go for is a replacement battery. Even a used one that's working well would tell you if yours is the cause of the problem.
    But paying a shop to try all these things (if you can find an honest rpair person who will go through it all for you) would probably be too expensive.
    01-08-2016 05:49 PM
  4. noambason's Avatar
    Hello again,
    Belodion, I've already tried that and those apps shows me the same as the system shows me. 100% all the time.
    Rukbat, thank you but as I wrote in the body of the message I've done all of your suggeztiins without success..
    It could be either
    01-10-2016 04:23 AM
  5. Fred_Eric's Avatar
    Hi,
    Are you still having issues with the battery indicator ?
    I'm interested in the solution mine is stuck at 0% whatever I do.
    01-17-2016 03:13 PM
  1. Replies: 4
    Last Post: 11-02-2016, 05:06 AM
  2. Replies: 4
    Last Post: 01-10-2016, 10:23 PM
  3. Replies: 3
    Last Post: 01-08-2016, 08:11 PM
  4. Replies: 1
    Last Post: 01-08-2016, 07:56 AM
  5. Why won't my wifi turn on?
    Last Post: 01-08-2016, 04:22 AM
