1. BIGLEX911's Avatar
    So, I had my N5 since 2013 and the battery as the updates went around (I am sure everyone knows) was up and down until Marshmallow came out, it was amazing. Great speed , battery and everything, but i broke my own rule and updated to 6.0.1 as soon as i was able to. Well since then the battery isn't so good, and whenever I use heavy apps (primarily when i try to multitask between them) the phone will black out and will turn back on with a chunk of battery missing or it used to be dead. Again this only started with new update so I cant totally point at the battery being old as the problem, but as a new bug with update. I cleared cache and reset it. I tried to downgrade it but kept saying there was missing images and such. My real question is. Am I the only one facing this problem or is anyone else? If I am not the only one at least that assures me it is a firmware bug and not my phone. I did just purchase a LG v10, but I would like to have this as a back up or give it to my father to replace his Moto G.
    01-08-2016 05:36 PM
  2. Rukbat's Avatar
    When this happens. and you get the phone running again, look at Settings/General/Battery. Tap the graph at the top to get the second graph.
    If you see a sudden drop to zero toward the right end of the graph, your battery is growing a dendrite. (See Lithium Battery Dendrite links to learn about them.) It means that the battery has to be replaced. (It's such a common problem with lithium technology that the automotive industry is spending billions trying to find a way around it - nothing yet, though.)
    01-08-2016 05:44 PM
  3. BIGLEX911's Avatar
    So, the phone shut off and i have a pic of the chart that does show a sudden drop. This is pretty much a fact of a dendrite is growing and not software? I wonder how much it would cost to fix this. I may just fix it myself, but would you know where to get a decent battery? Don't want to replace a dead battery with another cheap one that will die also. Nexus 5 random shut down and loss of battery-screenshot_20160108-203413.jpg
    01-08-2016 07:39 PM
  4. BIGLEX911's Avatar
    OK, so the chart shows a huge instant drop, I would h8 to replace with a cheap possible knock off battery, and im sure sending it in isn't cost efficient at all. I got off chat with Nexus support and he said to run it in safe mode for 24hours to see if maybe jt is an app issue possibly from new update. Will let you know tomorrow if it improves, hopefully it does!
    01-08-2016 08:20 PM
  5. rhea's Avatar
    If you decide to replace battery, this may be the best choice: https://lg.encompass.com/item/103895...ithium_Polymer. Shipping is $7.00, I think.
    01-09-2016 03:24 AM
  6. FredGag's Avatar
    my phone is doing the same, what happened with yours?!
    Thanks!
    04-08-2016 10:49 AM
  7. electronicwiz1's Avatar
    My phone did this a year ago where it would just shut off and go black while using it. I fixed it by replacing the battery in the phone! So it's just a bad battery!
    04-14-2016 12:21 AM
  8. sairupak's Avatar
    Hi
    Did you issue get resolved. I'm facing the same issue after moving to 6.0.1 on Nexus 5
    Thanks
    Sairupak
    05-16-2016 07:09 AM
  1. Replies: 2
    Last Post: 01-08-2016, 05:44 PM
  2. is there a type of galaxy 5 widget that..
    Last Post: 01-08-2016, 05:20 PM
  3. is there a type of galaxy 5 widget that..
    By davidson429 in forum Samsung Galaxy Note 5
    Last Post: 01-08-2016, 05:18 PM
