1. AC Question's Avatar
    Hi,
    My Nexus 5 dies, even when on full or substantial charge, if it isn't connected to a charger. Also, when it dies, the only way to reboot it is if it is connected to a charger. When the phone is rebooted, it will still have a substantial charge, i.e. whatever it was before it died (even if it was 95%).
    I just factory reset the phone and the problem is persisting. Please help - this has been happening for months now. If I do have to change the battery, how do I go about doing this, seeing as there is no removable cover? Or is there a better way to solve this?
    Thanks.
    02-28-2016 09:32 AM
  2. belodion's Avatar
    It sounds like it may need a new battery. There are online guides if you want to do it yourself.
    Of course, it may not be a battery problem.
    02-28-2016 04:29 PM
  3. willo99's Avatar
    My Nexus 5 had a similar battery problem. I ordered a replacement battery online and switched it out easily on my own. The back isn't technically removable, but it's pretty easy to pop off. You just have to undo a few connections to get to the battery. There are guides online. This fixed my battery problem.
    03-22-2016 06:33 PM
  4. cdubb1's Avatar
    You'll also be blown away by the battery life this thing gets with a new battery. 👍
    03-22-2016 07:18 PM
  1. Galaxy S7 - Way to keep lighted buttons at bottom on longer?
    By dhinged in forum Samsung Galaxy S7
    Last Post: 04-22-2016, 02:57 PM
  2. Can I access Alexa on my Note 5?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 02-28-2016, 11:37 PM
  3. How do I find the PIN on my ZTE Max for pairing?
    By AC Question in forum Other ZTE Android Phones
    Last Post: 02-28-2016, 09:55 AM
  4. Replies: 4
    Last Post: 02-28-2016, 09:35 AM
  5. Replies: 1
    Last Post: 02-28-2016, 09:05 AM
