05-18-2016 06:47 AM
39 12
tools
  1. Zakaria Ouh's Avatar
    Hey everybody.
    I have a nexus five running 6.0.1
    My battery life seems bad.
    my battery percentage drops down fast
    but when i go to battery usage to see what kills my battery,i find that the Consumed percentage there isn't exact like in the embeded battery percentage.
    wether my battery isn't calibrated or i got a hidden killer.
    please anyone could explain to me what could be my issue.
    04-15-2016 07:42 AM
  2. B. Diddy's Avatar
    The total percentage of battery use by the listed apps doesn't necessarily add up to the total that you observe was actually used.
    Show us some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    04-18-2016 03:09 AM
  3. Zakaria Ouh's Avatar
    i cannot post photos i dont know why
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-11977.jpg
    04-21-2016 05:44 PM
  4. Zakaria Ouh's Avatar
    here's one i will try t post the others
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-11978.jpg
    04-21-2016 05:45 PM
  5. Zakaria Ouh's Avatar
    04-21-2016 05:46 PM
  6. Zakaria Ouh's Avatar
    here's another one
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-11979.jpg
    04-21-2016 05:50 PM
  7. Zakaria Ouh's Avatar
    here's the last one
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-11980.jpg
    04-21-2016 05:50 PM
  8. B. Diddy's Avatar
    Sorry--it's best to let it drain down to 20-30% and show us the stats, not down by 20-30%. So charge up to 100%, then use it until the battery level is reading 20-30%.
    04-22-2016 03:03 PM
  9. Zakaria Ouh's Avatar
    Ok dear i will charge it now.
    i will be posting thr screenshots tonight.
    04-22-2016 03:33 PM
  10. pgoelz's Avatar
    Well known issue (at least to me).
    https://code.google.com/p/android/is...ummary%20Stars
    Still carefully observing, but it appears to be fixed with build MOB30D.
    Paul
    B. Diddy likes this.
    04-23-2016 12:06 PM
  11. Zakaria Ouh's Avatar
    I already Have the MOB30D build.
    i just recieved another update of 6.0.1 and thought it would fix the problem but it didnt.
    i don't know how to fix this problem.
    can anyone please help us.
    04-23-2016 09:16 PM
  12. Zakaria Ouh's Avatar
    here are the new screenshots
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-19330.jpg
    04-24-2016 10:35 AM
  13. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-19331.jpg
    04-24-2016 10:36 AM
  14. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-19332.jpg
    04-24-2016 10:36 AM
  15. B. Diddy's Avatar
    Something is keeping the phone awake a lot, which could impact battery usage. Unfortunately, it can be difficult to tell which app it is using the stock battery menu. Try using GSam Battery Monitor, which can give more details.
    The total percentage of battery use if you add up the apps listed in that menu often don't correspond with the actual battery used. I'm not exactly sure about the algorithm, but there may be some unreported apps or services that use battery, or there might be a number of apps that use a fraction of battery (which don't get reported, but that add up to a significant percentage).
    Out of curiosity, why are you on 3G? Is there no 4G LTE where you are, or are you purposely forcing it to go to 3G?
    04-24-2016 07:15 PM
  16. Zakaria Ouh's Avatar
    thank you For your response.
    i force my phone to turn to 3G as 4G signal is weak in my house which makes the phone goes to emergency calls only state and drains the battery.
    i even Did calibrated my battery after i received another update of 6.0.1
    but my battery is still draining.
    I will use the app you mentioned and see.
    thank you again dear.
    04-24-2016 11:01 PM
  17. Zakaria Ouh's Avatar
    hi after i installed the app you mentioned here's what i found.
    can you please explain to me what causes the problem?
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-20888.jpg
    04-27-2016 06:23 AM
  18. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-20889.jpg
    04-27-2016 06:23 AM
  19. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-20890.jpg
    04-27-2016 06:24 AM
  20. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-20891.jpg
    04-27-2016 06:25 AM
  21. belodion's Avatar
    It's difficult to tell very much after only 50min of usage. Could you use the phone normally until you need to recharge - at 20-30% charge remaining as B.Diddy suggests - and then post screenshots of the stats?
    04-27-2016 08:47 AM
  22. Zakaria Ouh's Avatar
    hey sorry for answering too late i've been busy.
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-31574.jpg
    05-13-2016 02:31 PM
  23. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-31573.jpg
    05-13-2016 02:31 PM
  24. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-31571.jpg
    05-13-2016 02:31 PM
  25. Zakaria Ouh's Avatar
    Attached Thumbnails Lg nexus 5 Battery percentage isn't accurate to battery usage in settings-31572.jpg
    05-13-2016 02:32 PM
39 12
  1. lg l22c blue screen shutoff and won't turn on again
    By Tina Ogden in forum More LG Phones
    Last Post: 04-18-2016, 03:16 AM
  2. How do I watch recordings?
    By AC Question in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-18-2016, 03:15 AM
  3. Replies: 1
    Last Post: 04-18-2016, 03:13 AM
  4. How do I grant an app access to my Google account?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 04-15-2016, 07:02 AM
