Re: No removeable battery is a deal-breaker for Nexus 6
Great phone, the specs seem really nice including the 2560x1440 resolution that should match the screen size well. But the lack of a user-removable battery is a deal breaker for me.
The phone of this caliber seriously needs a 10,000 mAh cell, at least optionally (such as zerolemon, etc.) because of the increased drain the higher resolution will require.
You've brought up this same thing at least
two separate
times before. Does it really warrant another dedicated thread?
Show me one phone that was available at launch with a 10,000mAH battery standard.
No? Ok, how about one that had a 10,000mAH replacement battery announced before the phone was available.
No? Hmm... Ok, how about a 10,000mAH external battery pack that can be used to charge the phone. EUREKA! Oh wait, but those meet that minimum requirement you specify with any phone you would want.
Your personal needs are at the far, far end of the bell curve, and manufacturers are not building phones for the 1/2 of 1%, especially when those needs can be met by accessories. Any way you look at it, on any device you choose, to meet the minimum standards you set for yourself you're going to have to carry around extra bulk in the form of additional internal batteries, a massive battery case, or an external battery pack.
The other 99.9% of us will just remember to occasionally throw it on a turbo charger (Qualcomm's Quick Charge 2.0 is a
winning feature) or keep a battery pack in the glovebox/purse/backpack/wherever if we know we might be without access to an AC outlet for a while.
But if for you, "deal broken," so be it - it is, of course, your option to refuse any phone you like. I myself am having a very difficult time overcoming my objection to the Nexus 6's failure to meet a rule I set for myself after my last upgrade, wherein I'd intended to never, ever buy a phone again unless it had a built-in espresso grinder. Curse you, Nexus 6! Guess I'll buy it anyway... Btw, anyone know where I can get a USB-powered coffee grinder?
Edit: ok, 1/2 of 1% + 99.9% > 100%, but I never said I was mathematically inclined. Still, probably no more than 7 out of 6 of you would have caught that error.
