1. garrim85's Avatar
    I know the Google devs talked about not having it for battery reasons but I really do miss being able to glance up top and seeing the battery %. Any way to bring this back?
    11-21-2014 03:41 PM
  2. klau25's Avatar
    you can if you install an app, or rooted
    I didn't know they don't put it for battery reason. just thought they were stumbled. like how they have to make such a big phone, or qhd screen, or take away my led. haha yes I'm bitter
    11-21-2014 03:47 PM
  3. anon(5600632)'s Avatar
    Not without a new app. There's a million of em in the play store, many of them super light with no troublesome permissions. Power toggles includes it or you could just go with a single purpose battery indicator.
    cerob likes this.
    11-21-2014 03:48 PM
  4. XSSIVE's Avatar
    The same "Battery Percent for KitKat / L" app I used on my nexus 5 worked on my 6 and it shows your percentage in black text right over the stock battery icon. It's free in the play store.
    cerob likes this.
    11-21-2014 04:00 PM
  5. garrim85's Avatar
    This one is perfect, thanks!
    11-21-2014 09:40 PM
  6. klau25's Avatar
    how do you get it to display black text?
    11-22-2014 04:12 AM
  7. Hasbrobot's Avatar
    I'll second that
    11-22-2014 05:20 AM
  8. klau25's Avatar
    just realized, it's no longer white text over white, it's black over white now. just need to reset it first!
    11-22-2014 06:41 AM
  9. N4Newbie's Avatar
    I don't feel the need to know the exact percentage; the icon is enough for me.
    Having said that, I use HD Widgets for many of its features and one of them is a battery widget which shows the current percentage and, when tapped, takes you directly to the battery settings page.
    11-22-2014 07:32 AM
  10. Storm24's Avatar
    I use the circle battery widget on my home screen. Nice, neat, and accurate.
    11-22-2014 07:34 AM
  11. Hasbrobot's Avatar
    Reset it first?
    11-22-2014 08:44 AM
  12. klau25's Avatar
    Reset it first?
    I meant reboot. also. if it's at 100% it won't show the percentage in number, just full battery. the percentage in number will only show if it's at 99% or lower.
    I included a screen shot to show you.
    Attached Thumbnails Battery % without bringing down quick settings?-11234.jpg
    Hasbrobot likes this.
    11-22-2014 09:18 AM
  13. Hasbrobot's Avatar
    Thank you!
    11-22-2014 12:25 PM
  1. Why has my Android OS reversed and flipped upside down?
    By Jessica Rabbid in forum Legacy Android & Other OS's
    Last Post: 09-16-2016, 10:41 PM
  2. Nexus 4 guest user battery drain?
    By Clark Ye in forum Google Nexus 4
    Last Post: 11-22-2014, 09:29 AM
  3. Excessive Battery Drain
    By Nuno Leonardo in forum Sony Xperia Z1 Compact
    Last Post: 11-21-2014, 02:55 PM
  4. Why is my S5 changing settings back to default on its own?
    By Zonayork in forum Legacy Android & Other OS's
    Last Post: 11-21-2014, 02:46 PM
  5. without power button
    By donb2010 in forum Samsung Galaxy Note 4
    Last Post: 11-21-2014, 02:21 PM
