My ear/face keep hitting the hold/mute buttons while using the phone (As a phone), how do I stop this?
kentsoro
I find this to be a huge problem, but haven't seen any other complaints about this... when using the phone (As a phone), I frequently find that my ear or the side of my face that's touching the screen is causing the mute or hold (or others) buttons to be pressed which needless to say causes big problems when it's being done unintentionally.
Anybody else have this problem/issue and know anything that can be done about it? Yes, I can hit the home screen after dialing, but it's still a problem because my ear/face is potentially hitting other Apps, or music to play or something else instead... plus I still want the ability to actually pause, intentionally or mute...
milehigherik
660
Re: My ear/face keep hitting the hold/mute buttons while using the phone (As a phone)
Sucks but hit the power button before placing the phone to your ear
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
I lock my screen too. The only time I don't is when I call my bank and use the key inputs.
From an AOSP M8
brosko
1,466
http://forums.androidcentral.com/google-nexus-6/479320-nexus-6-0-2-horrible-phone.html
N4Newbie
Trusted Member
Nov 15, 2012
5,006
So, just curious: are you left-eared or right-eared?
N4Newbie
Trusted Member
Nov 15, 2012
5,006
Why I inquired:
Begin a telephone call. Hold the phone in your hand, in front of you. Once you hear the ring signal, place a finger over the left top edge of the phone's screen, about 1/4 to 1/2 inch above the surface. You should see the screen go black as you trigger the proximity sensor. Move your finger around a bit to locate the exact location of the sensor and it's sensitivity.
What I find is that the sensor is far more likely to be properly triggered when I hold the phone to my left ear as compared to my right.
When triggered during a call, the screen goes black and all on-screen buttons are deactivated.
Ed Briggs
1,004
When placing the phone to your ear, the screen should go black and nothing should happen. Never heard of this problem.
JoePa2624
126
This has been an annoying software bug for me as well. I've hung up on a few calls and started dialing random numbers. The software needs to be fixed so that the screen fades when it senses that its being up to your ear.
I thought this was fixed years ago.
Sent from my Nexus 6 using Tapatalk
Jeremy8000
2,567
159
63
Place a test call, put your finger or hand over the sensor (you don't have to completely cover it, but get close). If it consistently works, it is not a software issue, but rather the way you put it against your head (hence why some people report the issue only when held to one side of the face and not to the other). If the results are inconsistent when covering the sensor at the same distance, then it's a hardware/software issue, but in most cases it's just the way the phone is held (design flaw).
Aug 20, 2015
I am also facing the same problem after updating my phone os from kitkat to lollipop 5.1. the mute/hold buttons should have been a bit lower then they are now.hope google will fix it up
mattimoe8
I am left handed and the phone goes to my left ear which puts the call on hold every time. Please don't tell me to switch ears or I'm holding it wrong - design flaw. Marshmellow better have the fix or I'm done with Nexus phones. Google's flagship phone should not have these issues.
jj14x
995
24
I have same problem with my Droid Turbo
Same for me since lollipop
i am having this same stupid problem
Did any of you try the suggestions/directions that @N4Newbie & @Jeremy8000 gave? That will help identify whether it is a hardware/software issue, or design issue.
milon30
Me also facing this horrible problem with my Galaxy A-8 and now using "Customize My Caller Screen" apps and my problem solved.
Muilisx
7
it mostly happens when you have it on your right side using ur shoulder to hold the phone. The phone leans out a little to where the prox sensor thinks it's away from your face so the screen becomes active. It's super annoying. It forces me to use my left side or lock the phone.
adaorange
68
5
This is happening to me in my s6 edge plus. Super annoying.this is unacceptable. Phone needs to work as a phone without the user needing to walk on eggshells to avoid failure. Ugh.
Dynoble
I feel your pain. I just got the S7 and this happens to me as well when I don't have the phone completely on my ear. I use my left hand when talking so my ear hits the damn hold button when it's not covering the sensors. Basically you just need to have your ear over the sensors.
kiaara
