1. AC Question's Avatar
    I have the nexus 6 and I need to replace the battery where can I get the battery
    05-28-2015 06:27 PM
  2. belodion's Avatar
    Wherever you buy it, and there are many sources of supply online, for example, make sure you get the genuine article. Some new batteries are so bad that users find their old batteries actually perform better. Try the device manufacturer....there's no harm in asking.
    05-28-2015 07:06 PM
  3. Rukbat's Avatar
    Since the battery is non-removable, I strongly urge you not to. Bring it into a shop and pay them to do it. If you aren't experienced with working inside cellphones, you could easily damage something just by opening it up, then have to fix that, breaking something else, etc. - ending up costing you a lot more than paying to have a battery installed would have cost. (Just pulling the back off some phones damages components.)
    belodion and Crashdamage like this.
    05-28-2015 11:19 PM
  4. belodion's Avatar
    Oh yes, I hadn't thought of the non-removable battery in that device.
    05-29-2015 07:03 AM
  5. doggy2965's Avatar
    If phone is less than a year old warranty still in effect return it to motorola
    05-29-2015 03:50 PM
  6. N4Newbie's Avatar
    And it must be less than a year old since the Nexus 6 only went on sale last November. I am curious to know why the OP thinks he needs a new battery...
    05-29-2015 05:41 PM
  7. choclab1's Avatar
    Yea I'm thinking there is something to this post. That phone is less then a year old. Send it in for warranty.
    Posted from Nexus 6
    05-29-2015 06:27 PM
  8. JimSmith94's Avatar
    05-30-2015 12:31 AM
  9. Michael Danesie's Avatar
    01-15-2017 01:55 PM
  10. Michael Danesie's Avatar
    Yes my name is Michael I have hey Nexus 6 that needs the battery changed
    01-15-2017 01:58 PM
  1. The new Google Photos are still using cloud drive storage.
    By tonyr6 in forum General Help and How To
    Last Post: 06-04-2015, 07:24 PM
  2. Can I load Nexus 6 image on Nexus 5
    By steven0188 in forum Google Nexus 5
    Last Post: 05-29-2015, 12:32 AM
  3. How can I recover my backup password for my Galaxy Edge?
    By AC Question in forum Samsung Galaxy Note Edge
    Last Post: 05-29-2015, 12:13 AM
  4. Replies: 3
    Last Post: 05-28-2015, 11:26 PM
  5. Replies: 1
    Last Post: 05-28-2015, 06:04 PM
