1. ybcthanerd's Avatar
    i have used head phones and my aux cable in my car. My music sounds like its 30 feet away. th only way it sounds proper is if i have the charger plugged in. and i have a personal and work nexus 6 both have the same issue.
    06-10-2015 02:57 AM
  2. B. Diddy's Avatar
    When you plug into the headphone jack, are you feeling or hearing it click into place? If the plug isn't in securely, that can give the hollow/faraway sound.
    Also make sure there isn't any debris in the jack. Use a damp toothpick to root around, or blow it out with a can of compressed air.
    06-10-2015 12:25 PM
  1. How can I reinstall Samsung S Voice on my Galaxy Tab S?
    By AC Question in forum Samsung Galaxy Tab S 8.4
    Last Post: 08-11-2015, 09:31 AM
  2. nexus 5 2015 for Verizon ? or just get nexus 6
    By Seremedy in forum Google Nexus 6
    Last Post: 07-08-2015, 10:46 PM
  3. 4G connectivity issues
    By Shaygol in forum LG G3
    Last Post: 06-11-2015, 08:32 AM
  4. any companies that will replace nexus 9 front glass.
    By Seremedy in forum Google Nexus 9
    Last Post: 06-10-2015, 07:06 AM
  5. Replies: 1
    Last Post: 06-10-2015, 02:08 AM
