1. MikeCallery's Avatar
    I have a Microsoft Display Adapter on my tv. Previously I was able to screen cast of my Samsung Note 4 to the MDA w/o any problems. Now that I have moved to a Nexus 6 they do not seem to locate each other. I really thought, being clean Android, that if anything I'd have a quicker, easier connect and stream but that isn't the case.
    Has anyone played around with an MDA and gotten it to work? I just bought a Chromecast which should work, if not, I might have a flaw with the phone, but I doubt that.
    Now, as I know this will be asked, I tried the cast screen off the drop down, but my gut tells me that is for chromecast specifically. I've tried, unsuccessfully, numerous apps without success.
    Thank you.
    08-18-2015 02:14 PM
  2. metle_geek's Avatar
    That's BC the Samsung supports WiFi direct.. Your going to have to go into your WiFi settings and see about a wifidirect connection in advanced... Or you could get a chrome cast.. I love my chrome cast!! I can cast it all or YouTube Netflix..
    08-18-2015 03:50 PM
  1. Replies: 2
    Last Post: 01-03-2017, 02:07 AM
  2. Help
    By Ebraaz Khan in forum Ask a Question
    Last Post: 08-20-2015, 12:48 AM
  3. How do I stop the screen from rotating
    Last Post: 08-18-2015, 10:34 PM
  4. Replies: 1
    Last Post: 08-18-2015, 02:05 PM
  5. Why doesn't Sky go fill the screen on my HTC One M9?
    By AC Question in forum HTC One M9
    Last Post: 08-18-2015, 01:44 PM
