1. AC Question's Avatar
    This seems to happen quite frequently. I'll be going about my day at work or home and suddenly I see that my phone lost connection to the wifi again. So i have to reset the wifi on my phone to get it to reconnect.
    Is there some way to fix this issue?
    11-10-2015 08:40 AM
  2. IAmSixNine's Avatar
    Try to forget it and then add it back as a new wifi connection.
    Also might want to check and see if your on the fringe of coverage or getting interference. I find that my Nexus 6 has weaker antenna then some of my other devices. Meaning i get better, stronger wifi on my Note 4 and M9 then on my Nexus 6.
    11-10-2015 04:19 PM
  3. robert7107's Avatar
    I had the same issue I believe lollipop to be the culprit mainly 5.1.1.. On good note I don't have the problem anymore since updating to 6.0... Just hang in their!!!
    11-11-2015 05:08 PM
  1. my mail failed to send show sending but actually not
    Last Post: 11-24-2015, 04:26 AM
  2. Replies: 1
    Last Post: 11-22-2015, 09:29 PM
  3. Is my S5 receiving the Internet?
    By ChiefDog in forum Samsung Galaxy S5
    Last Post: 11-10-2015, 07:12 PM
  4. why i cannot use a 3g internet ?
    Last Post: 11-10-2015, 08:55 AM
  5. Replies: 1
    Last Post: 11-10-2015, 08:53 AM
