1. EN4CER's Avatar
    Is there a way to switch between card view to grid view on a Nexus 6?
    I was recently able to do this on my HTC M8 running Marshmallow, but just upgraded to the Nexus 6 and can't find a way.
    Thanks for your help.
    Brooky
    01-27-2016 04:32 PM
  2. VW Maverick's Avatar
    Are you referring to the Google Now cards?
    Mav.
    01-27-2016 04:42 PM
  3. EN4CER's Avatar
    No, the cards that are displayed when you press square button in the bottom right hand corner.
    It shows stacked cards, I want to be able to display all the cards in a grid view.
    01-27-2016 06:33 PM
  4. LeoRex's Avatar
    Brooky
    About your only option would be a custom ROM.... There may be an Xposed module, but a ROM would be the best solution.
    Javier P likes this.
    01-27-2016 07:26 PM
  5. rcowdery10's Avatar
    It's a HTC only software feature I'm afraid.
    01-28-2016 04:24 AM
  6. EN4CER's Avatar
    Thanks for that. I'm going back to My HTC.
    01-28-2016 04:30 AM
  7. EN4CER's Avatar
    Is there any launcher that can replicate it?
    01-28-2016 01:52 PM
  8. Javier P's Avatar
    No, I'm afraid. A custom launcher can control your home screens and app drawer, no more than that. As LeoRex said a custom ROM is your best option.
    01-28-2016 02:04 PM
  9. EN4CER's Avatar
    Thanks for your explanation. Do you know of a good custom Rom that will achieve what I want?
    01-28-2016 02:23 PM
  10. LeoRex's Avatar
    Being a Nexus, there are dozens upon dozens of custom ROMs out there. I would suggest you head on over to XDA Developers and to to the Nexus 6 forums and start looking. I wish I could give you a definite answer, but it is more a question of personal taste and what you want... Hard for me to recommend anything.
    MikeCorsten likes this.
    01-28-2016 02:41 PM
  1. Switching from iPod Touch to an Android
    Last Post: 01-29-2016, 01:35 PM
  2. Replies: 6
    Last Post: 01-29-2016, 07:01 AM
  3. Kate Spade Charging Case not working, how can I get it working?
    By VanessaK82 in forum Samsung Galaxy S5
    Last Post: 01-28-2016, 05:33 AM
  4. how i can see all my photos in picasa tool app
    Last Post: 01-27-2016, 03:59 PM
  5. How do I print with Kakao, I have the HP Plugin installed?
    Last Post: 01-27-2016, 03:41 PM
