Bluetooth Audio Problems with Nexus 6
I'm hoping someone else has experienced this problem and can help because no searches are helping. I have a Google Nexus 6. Sometimes when I connect to a bluetooth speaker, the app is actually controlled by the bluetooth device (skip, pause, play, etc.) but the audio comes out of the phone's speaker instead of the bluetooth speaker. This most often happens when I'm listening to the SiriusXM on demand app through my Ford C-Max with the Sync system. It will work fine and connect automatically and work fine a few times. Then the next time I'll hear the audio coming out of my pocket instead of the car. The only thing that seems to fix it is to restart my phone. But that only works a few times, then I have to power down the phone again. I've also had it happen with other apps like Pandora. It's also happened with a portable bluetooth speaker. as I was troubleshooting. I think maybe it started around the time I did a factory reset on my phone once. I've tried every combination of deleting the Nexus 6 from the Sync system, disconnecting bluetooth, erasing the Sync from my phone, etc. The only thing that seems to work is to restart the phone. Any ideas what I'm dealing with?
